Ver 7.3.1.0 Released
Posted: Mon Mar 01, 2021 9:32 pm
by rbentnail
As the title says.
GE 7310.JPG (18.82 KiB) Viewed 4921 times
Re: Ver 7.3.1.0 Released
Posted: Sat Mar 13, 2021 10:00 am
by colirv
Is this the one that won't allow you to save maps on your computer?
Posted: Sat Mar 13, 2021 12:55 pm
by rbentnail
colirv wrote: Sat Mar 13, 2021 10:00 am Is this the one that won't allow you to save maps on your computer?
Nasty rumor?
Posted: Sun Mar 14, 2021 9:59 am
by colirv
From other forum it seems that XT users have found that upgrading to the latest firmware means that Garmin Express is updated to the latest version and there is no longer the option to save maps to the computer as well as to the XT. This has been observed for both 7.3.1.0 and 7.4.0.0. I imagine it will need observations from other users to show if this problem is unique to the XT.
Posted: Sun Mar 14, 2021 3:14 pm
by MSTOCK27370
colirv wrote: Sun Mar 14, 2021 9:59 am From other forum it seems that XT users have found that upgrading to the latest firmware means that Garmin Express is updated to the latest version and there is no longer the option to save maps to the computer as well as to the XT. This has been observed for both 7.3.1.0 and 7.4.0.0. I imagine it will need observations from other users to show if this problem is unique to the XT.
I have checked Express version 7.3.1.0 and updated to version 7.4.0.0. Using either version, the option to load maps to the computer is still available. This issue appears to be unique to the Zumo XT with the newest firmware. There is some interaction between the XT and Express, so that Express no longer shows that option when it sees an XT. I have tested this on a Nuvi 54, Zumo 450, 550 and 590. They all worked.
Posted: Sun Mar 14, 2021 6:21 pm
by colirv
I wish now I'd hung on to the 595!
Posted: Sun Mar 14, 2021 7:09 pm
by mzeist
as long as your 595 is listed in Express you can still install maps to your pc..
Posted: Mon Mar 15, 2021 9:41 am
by colirv
Thanks. I shall try that the next time there's a new map update.
Posted: Mon Mar 15, 2021 11:16 am
by mzeist
as will I ;-)
