Map Source doesn't are Zumo XT
Snurrepus
Norway
Re: Map Source doesn't are Zumo XT
Post by Snurrepus »
Search for MapSource 6.16.3.
No limitations.
You can build maps om all units and sd-cards.
Honda Varadero XL1000VA 2008
Zumo 660
Has liked: 378 times
Been liked: 384 times
MapSource will only work with units in mass storage mode, most modern units by default are in mtp mode so need to be set to mass storage, and it seems that can't be done with the XT.
