Adding Songs to SD card
Posted: Sat Apr 24, 2021 3:51 pm
by Scarecrow
Do my need to take the sd card out of my unit to add songs
Re: Adding Songs to SD card
Posted: Sat Apr 24, 2021 6:53 pm
by electro_handyman
No, you can transfer the music with the Zumo connected to your computer, but probably should not be running Express or Basecamp as they may put locks on access(though I don't know for certain).
You do need a folder named "mp3" in the root of the sd card, other than that it's just copy/paste from your computer to the mp3 folder.
You can have sub folders for sorting your music if you would like. I have mine sorted 1st by Genre, then by individual artist.
The XT will still see all the files and allow you to select how you want them played.
Posted: Tue Jun 15, 2021 8:18 pm
by HipGnosis
Note: If you have any .mp3 files in the internal memory /mp3 folder, the Zumo won't show you the SD card as a source for playing music.
