Tyre to XT
Posted: Fri Jul 16, 2021 6:29 pm
I'm an old Tomtom + Tyre user now with a Zumo XT.
So I'm used to pick a set of Waypoints in Tyre transfer them as an itinerary to the SatNav unit and let it find the best route.
That was the way I was using Tomtom and it seemed to work fine for years. Now Tomtom didn't made much use of tracks (at least until now which seems to be available on the latest units). I'm aware about the differences between routes and tracks and I know Garmin is been using both since a long time.
Tyre will actually generate both (it uses google maps for routing).
So I was pleasantly surprised when Tyre allowed me to transfer my itinerary (gpx) directly to the XT.
I would then open the itinerary in the Trip Planner and all waypoints were there.
Track seemed also to be loaded as it was drawn on the map with narrow blue line.
So from understanding...
Track (which was calculated by Tyre) is drawn with a blue line but navigation (magenta line) finds the path from the waypoints.
I transferred two or three itineraries like this and it was working all as expected.
But last weekend I've done same process and I got the "Unable to calculate path" message...
Tried to erase some waypoints on Tyre but no matter what it was still unable to find a path.
After 1 hour fighting I decided to try basecamp...
Basecamp imported the Waypoints but gave a weird routing, had to correct it with several shape points to make it look like it was in Tyre.
Transferred to XT and finally the Trip Planner would accept the route.
I then erased all shape points on the XT and it had no problem on finding a route by itself, so definitely not a waypoint problem.
At this time it could only be the track calculated by Tyre which may had a bit of the path in some weird road that the XT couldn't found...
Could this be right?
Also is it possible to store only the waypoints on the gpx with no track data and load it in the Trip Planner?
Thanks.
Thanks.
