Export csv file anomaly
Posted: Mon Oct 04, 2021 4:23 pm
In summary this query is about exporting a track or tracks from Basecamp to a CSV file; the resulting list of Points are all one hour behind the real time during BST.
I do three or four long walks per week and download them from my GPSMAP 64ST each evening then store them in Basecamp. I also keep an analysis in Excel so it is easy to play about with the data.
If I am looking at any one walk in particular I use Basecamp export function and create a csv file to show me all the recorded points for that walk. When we are on Summer Time (BST) the time showing when opening the csv file in excel is exactly one hour earlier (presumably GMT) than the real time of the walk. The GPSMAP always has the correct time set, my pc has the correct time and they are identical so I wonder why this might be? Where is it getting GMT from?
As an aside I occasionally export a batch of walks to a gpx file for importing in to Mapsource (because mapsource produces a better format for my excel history; which is another story). When I do this the start time of the walk is always correct.
