595 Not Showing The Next Street Name
Posted: Fri Oct 15, 2021 11:05 pm
by rbentnail
Something I noticed today for the first time, anyone know of a "fix"?
I'm riding along, 595 on, looking for an upcoming street. Because we all know if you're not running an active route, the 595 shows the name of the next street to intersect with the one you're on. Right? At least this is the way it's always been until today. Today the thing shows the distance to my nearest Saved place in the green bar across the top of the display, but still no active route to follow. WTH? No matter what I tried I could not get it to stop that and tell me street names.
Any ideas?
Re: 595 Not Showing The Next Street Name
Posted: Sat Oct 16, 2021 4:29 am
Haven't got a clue, Russ.
But have you changed the voice ? I know that your question has nothing to do with spoken messages, but the voices with the 'real directions', and / or TTS seem to have access to different information. What is spoken is often reflected in the top bar display.
Just a random thought.
Posted: Sat Oct 16, 2021 9:14 am
by rbentnail
Nope, I haven't changed a parameter, voice, or anything else in more than a year.
Posted: Sat Oct 16, 2021 2:01 pm
Hmm..
Voices and possibly an additional map (like OSM) being selectected in myMaps are all that I have got on that one.
My 590 is in 590 mode at the moment, rather than its usual 595, so I cannot check easily.
Posted: Sat Oct 16, 2021 8:15 pm
by MSTOCK27370
rbentnail wrote: ↑Fri Oct 15, 2021 11:05 pm
Russ, I have had the same (or similar problem pop up once or twice. Went to meet some friends for breakfast. After, leaving the parking lot, the display is showing up showing distance to my home location, and I didn't do anything to the 590 to cause this. I think I might have used the fast shut off instead of the long hold of the power button. Normally, I always shut the 590 off with the long hold of the power button. After I got home and shut it down, the next time I used the 590, it worked normally and continues to do that. Do you usually shut down with the quick push of the power button, or the shutdown method?
Posted: Sat Oct 16, 2021 9:33 pm
by rbentnail
I always use the long press power off method. I haven't used the device since it did it so I can't say if anything's different again.
