Hi All
Posted: Thu Jan 20, 2022 1:49 pm
by MrPGB
Hi All just got myself a Zumo xt.
Re: Hi All
Posted: Thu Jan 20, 2022 2:40 pm
Welcome. Have fun !!
Re: Hi All
Posted: Fri Jan 21, 2022 8:06 am
by Stu
Hi and welcome
Re: Hi All
Posted: Sat Jan 22, 2022 12:50 am
by rbentnail
Hello and welcome to the forum! Lots of good info here.
Re: Hi All
Posted: Mon Jan 24, 2022 4:36 pm
by Grayrat
New to the Garmin Zumo XT. Have had a 395lm for about 5 years. Just mounted both on new motorcycles. Not too difficult, but puzzled about my new Zumo XT. Seems to have a mind of its own. Nothing wrong with it, but not sure it is charging off the motorcycle battery. When I turn it off with the button on the back, sometimes I can turn it back on and sometimes to just stays blank? Tested it in the car and it worked off the lighter. Then I charged it on the computer and it works. I worked off the motorcycle battery for a day and then not. Everything else tied to the battery is working. Any tips.
Re: Hi All
Posted: Mon Jan 24, 2022 5:38 pm
Welcome to the forums.
With your XT in the bike cradle, the XT should switch itself on when it receives power from the battery.
Does it do that ?
If not test the voltage on the contacts of the cradle - make sure that you are getting power at the two pins. Mine shows 5.21v dc.
If not, check your in-line fuse and your connections to the bike power. If it comes from a fused circuit on the bike, check that fuse as well.
Then its a phone call to Garmin.
