Spoken guidance from 396 to bluetooth dongle?
Posted: Mon Feb 28, 2022 4:29 pm
I use my satnav for motorcycling. Back in the old days, I used a G395LM (which I still have) and a pair of Custom Fit wired earplugs which plugged into the bottom of the satnav by way of a 3.5mm jack plug. Everything was fine, but then I chose to upgrade to a G396, which does not have an audio jack socket, and I ended up having to buy a SENA SRL2 comms unit for £259. Now, one month after the warranty expired, the SRL2 has died. I phoned the supplier (Helmet City) who thought the chances of compensation were unlikely.
I have a bluetooth dongle, which can receive input by bluetooth, and produce output to its 3.5mm jack socket, which is exactly what I want. However, the satnav output is on two channels - 1) spoken guidance instructions, 2) media output. The dongle will connect only to the media channel, but not to the spoken guidance channel.
I am looking for a dongle (or equivalent, or phone) or some other solution to receive spoken guidance output to a 3.5mm jack socket so that I can use my wired earphones again. The only other alternatives appear to be stumping up another £259 to buy a new SRL2 which might only last two years, or reverting to my G395LM and my wired earplugs.
Is there another solution that I have missed?
