Internal battery
Richard_R
Been liked: 20 times
New Zealand
Internal battery
Post by Richard_R »
Does anybody know what the capacity of the internal battery is?
My XT battery seems to go flat after about 3-4 weeks of not being used with the GPS turned off which makes me think that the GPS probably does not actually turn off but rather goes into some sort of sleep mode.
My old TomTom 400 battery would last for months when turned off.
Has liked: 110 times
Been liked: 253 times
Re: Internal battery
Are you sure you're turning it off? On earlier models a short press = sleep, long press = off. I usually get at least 2 months of good battery with off on my 595.
Richard_R
New Zealand
Post by Richard_R »
Yes I get the checking for updates before turn off message.
Has liked: 424 times
Been liked: 241 times
Richard_R wrote: Wed Mar 09, 2022 5:06 am Yes I get the checking for updates before turn off message.
That's not turning off that's going to sleep mode
Press and hold the power button until you get the power off confirmation message
