My Bike repositioned sat nav mount
Posted: Tue Mar 29, 2022 11:17 am
First got the bike in June 2021,so i thought as the dealer would need the panels off to do the pdi,i might as well get them to hard wire the the gps power lead in somewhere,i have always had the sat navs on my bikes fixed on the brake reservoir with the appropriate ram ball mount,but for some reason the mechanic place it in the middle,obscuring the dash
luckily enough he left enough loose cable so i could move it,a proper mount bar can be purchased which fits on the inside of the windshield,but that looked liked it could make the gps unit vibrate,just changed the stock screen to a Givi Airflow
Steve
Steve
