Wrong map on Zumo 390
Posted: Mon May 23, 2022 7:46 pm
Hi everyone.
I've searched but can't seem to find a solution so I hope someone may be able to help me.
I've just updated - or tried to - my old Zumo 390 LM which had European maps on which included GB and Ireland.
After going through the Express update process it now has CN Europe NTU - 2023.10 Central and Eastern Europe installed.
For GB, there is now no street level detail and it seems to be just a very basic base map.(Previous updates worked fine as did another update to my later Zumo 395).
Express is only allowing me to reinstall the map that is on the device which is now the wrong one.
Any idea how I can reload the original map that it came with or at least choose to install the GB and Ireland part to make it useable?
Thanks in advance...
