Erasing Data
Posted: Tue Jun 07, 2022 5:55 am
by Scarecrow
Hi Guys
Is there a way to ease all routes and waypoint from my XT without doing a full factory reset.
Thanks in advance
Del
Re: Erasing Data
Posted: Tue Jun 07, 2022 11:58 am
by simoncrewe
Scarecrow wrote: Tue Jun 07, 2022 5:55 am Hi Guys
Thanks in advance
Del
Personally I would delete everything via Garmin Explore and then re - synch the XT with Explore.
Re: Erasing Data
Posted: Tue Jun 07, 2022 1:22 pm
by Peobody
If you don't use Explore...
For deleting routes: Go into Trip Planner > Saved Trips the tap the spanner icon (Wrench). The resulting menu contains an option to delete trips. There will then be the option to select all or individual trips.
For saved waypoints: Go into Where To? > Saved (or Favourites), tap the hamburger icon, the "Delete Saved Places".
Any routes stored on an SD card must be deleted manually using a file explorer while connected to a computer.
Re: Erasing Data
Posted: Tue Jun 07, 2022 1:46 pm
by Rofor
Peobody wrote: Tue Jun 07, 2022 1:22 pm Any routes stored on an SD card must be deleted manually using a file explorer while connected to a computer.
Or while you be connected to Basecamp...
Re: Erasing Data
Posted: Tue Jun 07, 2022 4:09 pm
by Scarecrow
Thanks Guys
Ever helpful as usual
Re: Erasing Data
Posted: Tue Jun 07, 2022 7:12 pm
by sussamb
Note you also need to delete any .gpx files in the GPX folder
