Additional Map
Posted: Tue Jul 26, 2022 6:13 pm
by stkm04
Hi there -
Preparing for vacation, I plan to buy a country map from https://www.garminworldmaps.com. Installation on my ZUMO 660 should be no problem. But I wonder how to get that gmapsupp.img file into Basecamp.I looked at their installation guide but unfortunate the links are broken.
Hence the question: Does anyone know how to convert a gmapsupp.img file for installation in BC?
Thanks!
Re: Additional Map
Posted: Wed Jul 27, 2022 6:15 am
by sussamb
You can't. What you can do is view it in BaseCamp if you put it on either a physical or virtual removeable drive. For more info see
https://www.javawa.nl/virtualdevice.html
Re: Additional Map
Posted: Wed Jul 27, 2022 1:35 pm
by stkm04
Hey!
Thanks for the link. Very good explanation!
