Using: Base Camp 4.8.11 with macOS Monterey 12.5
Problem: After adding Custom Waypoint Symbols To Base Camp Mac 4.8.11 - They Do Not Scale Up
I downloaded a few custom waypoint symbols from POI Factory and installed them in /Users/dco_buy/Library/Application Support/Garmin/Custom Waypoint Symbols
They appear in the Symbols list as expected, but they do not scale up to the size of the pre-installed symbols. They are about one-half the size.
The downloads have been either 24x24 or 32x32 in .bmp or .png format.
Am I missing something or does Base Camp Mac not handle them nicely?
Thanks
