Arrival Time When Setting Multiple Stops
crossi92
Post by crossi92 »
I'm new here so sorry if this has been discussed before, although I did a little searching and haven't seen anything yet. When I set a route that has multiple stops, the arrival time that is shown is for my final stop. Is there a way to have it show the arrival time of my next stop? Showing me the arrival time of my last stop is pointless since it will never be accurate until I am on my final stretch, and all I really care about anyway is the when I will get to my next stop.
Has liked: 373 times
Been liked: 383 times
Re: Arrival Time When Setting Multiple Stops
Yes, you can set additional data fields on the right hand side so you can have time and distance etc if you want showing to the next viapoint. There was a post with screenshots showing the datafields but I can't find it right now.
Has liked: 140 times
Been liked: 438 times
That arrival time display is a button. Tap it to see the available display options. There are 25 of them. Relevant to your wish are either "Next Stop Arrival Time" or "Time to Next Stop".
Also available are trip data options which I believe is what @sussamb referred to. Tap the 3 dots at bottom right then select trip data. It will open a new pane on the right listing three data points. Each of these is a button that contains the same 25 options.
Location references assume landscape mode on the XT.
crossi92
Post by crossi92 »
Awesome, thanks guys!
Has liked: 418 times
Been liked: 908 times
Welcome to the forums @crossi92 !
Pics and additional info are in my post from a couple of days ago. 2nd post down.
viewtopic.php?p=13431&hilit=trip+data#p13431
