Update can finish
Posted: Sun Nov 27, 2022 7:38 pm
by RBW
My Zumo XT started update but it stops and inform me that the internet connection WIFI is not working. However I am using this connection to write this message. Can I turn off the Zumo XT and start over?
Thanks for your help
Re: Update can finish
Posted: Mon Nov 28, 2022 8:01 am
by sussamb
Yes, but really better to use the cable to update maps to avoid potential wifi issues
Posted: Mon Nov 28, 2022 11:31 pm
by rbentnail
sussamb wrote: ↑Mon Nov 28, 2022 8:01 am
I disagree. I tried updating maps with Garmin Express and it always failed. Direct Wifi connection to my home router and the update was finished in less than 30 minutes.
Posted: Tue Nov 29, 2022 7:42 am
by sussamb
Glad it worked but you can't really disagree with my statement, which was simply that using cable avoids wifi issues
Posted: Wed Nov 30, 2022 8:24 pm
by Peobody
rbentnail wrote: ↑Mon Nov 28, 2022 11:31 pm
In my experience, a map updated on the XT via wifi was not known to Garmin Express. I say this because I ended up with duplicate maps on my XT after a wifi map update and then allowing a map update by GE on my next connection. At the time, GE reported an old map version on the XT so I thought the wifi update had failed. Once I noticed the duplicate I suspected that GE didn't poll the XT for current map information but just displayed the last map version GE was aware of. I believe I was trying to use GE to install the wifi updated map to my PC but couldn't. I don't know whether this was a fluke but I have stayed with doing updates via GE ever since.
@rbentnail, what is your experience with this? Can you use GE to install a map to a PC that is on the XT (updated via wifi)?
