screen capture images - where stored/access?
Posted: Sun Dec 04, 2022 1:27 pm
by BashStreetKid
Dear All
I hope the title isn't too confusing.
ISTR that screen images of the XT are captured and stored in the device system folder; but I've been unsuccessful in finding/locating them when connected to my PC?
Could someone kindly help point me to the appropriate folder, please.
TIA
Re: screen capture images - where stored/access?
Posted: Sun Dec 04, 2022 2:44 pm
by sussamb
If you mean when you take a screenshot they should be in the folder named Screenshot or SCRN on your device.
Posted: Sun Dec 04, 2022 3:07 pm
by BashStreetKid
Many thanks for your speedy reply.
Unfortunately, I cannot see either SCRN folder, or one named Screenshot ?? in Apps or Settings.
Am I looking in the right place - apologies for appearing rather dim-witted.
Posted: Sun Dec 04, 2022 4:15 pm
by FrankB
Assuming you're using Windows:
Connect the XT to your computer via USB.
Wait for the Zumo to appear in 'This PC'
You can find the files in: This PC\zūmo XT\Internal Storage\Screenshot
- Screenshot.jpg (50.76 KiB) Viewed 1745 times
Posted: Sun Dec 04, 2022 9:12 pm
by BashStreetKid
@sussamb
@FrankB
Thanks, both - that's indeed what I was looking for.
(Mistakenly, I'd thought they were sent to the Garmin program files in the C-drive - hence not being able to locate them. D'uhh.)
All sorted.
