Garmin Explore - creating Routes for Zumo XT
Posted: Mon Dec 19, 2022 7:12 pm
Hello everybody,
I have set up Garmin Explore with connection to Zumo XT with intention to easily create and transfer Routes (with guidance). Basecamp seems to complicated. But it is not working as I imagened so I am asking for your help here.
Garmin Explore on the PC (website). I can create Routes and the Routes are "automaticaly" transfered to Zumo XT. But when creating Routes on the PC, you select points and between points there is a straight line. The line does not follow the road. Also on the Zumo XT it does not follow the road. When starting the route, if I select the start to Coordinates (and not as default nearest entry point), a part of the Route goes on road, and mayority is still straight lines between my points. Weird, but I tried multiple times.
Then I installed Garmin Explore app on Android tablet. There I have no option to create Routes. But I can create a Course. It creates beautifuly! The selected points snap on the closest road and also the line between points is not straight but it follows the roads... perfect and done really easily. But Courses are not visible to Zumo XT so I cannot use them. I didn't find any option to convert Course to Route - not on tablet and not on the web page.
Is there some other trick or is Garmin Exlore just not the solution for Routes for Zumo XT?
Thanks and cheers
Thanks and cheers
