PROBLEMS WITH CALCULATION OF THE FUEL
giuseppe66
Has liked: 30 times
Been liked: 9 times
Italy
Post by giuseppe66 »
I have tried many times to set the fuel warning but I can not make it work. Every time I refuel, I reset the fuel tank and set a warning level to refuel, but when I start with the bike, after refueling, it tells me that I have to refuel. I did a complete reset of all the ZUMO but nothing, the problem continues. I asked GARMIN but they can not tell me what it depends on. I tried another ZUMO and he too has the same problem: I was hoping that a firmware update would solve the problem but nothing, not even the firmware. I did a CLEAR NON VOL in the hidden menu but not even that solved. Does anyone have the same problem?
Been liked: 265 times
Re: PROBLEMS WITH CALCULATION OF THE FUEL
What numbers are you entering out of interest?
I was doing it wrong to start and was having the same issue
giuseppe66
Has liked: 30 times
Been liked: 9 times
Italy
I've use and test on ZUMO 590 and ZUMO 595
I added a tank capacity of 28 liters, with a maximum range of 280 kilometers and a 200 kilometer fuel warning
Everything seems right by that!
Actually change the fuel warning to a lower amount
Moose
Been liked: 21 times
Post by Moose »
I set mine to zero so I don't get any warning my bike has a fuel remaining on the speedo
dave726
Has liked: 5 times
Been liked: 8 times
Post by dave726 »
Fuel reminder works great on my Z665. 200 mile tank, 50 mile low fuel warning. Why would the GPS need the tank capacity? It's not like it's monitoring fuel consumption. I like having that warning, as when I'm iding and listening to music, I sometimes forget to look at the fuel. An extra warning sure beats walking.
giuseppe66
Has liked: 30 times
Been liked: 9 times
Italy
Even my bike has a low fuel warning but I also wanted to use this gps option. If the American version works well I think it's due to a bug of the European version. It is the only explanation left
