Cleaning out internal memory on 590 & loading maps on sd card
Posted: Sat Mar 11, 2023 5:01 pm
As I was updating the maps on my unit, Garmin express said my internal memory was full. So elected to put the maps in the sd card.
After having done so (or thinking that I had done so), I plug the unit back into the pc.
BaseCamp shows TWO (City Nav North America 2024.1) map files on the 590 in the internal storage. This is puzzling to me.
Furthermore, if I open file explorer and look at the sd card, there appears to be nothing on it.
Can someone shed some light on this and tell me if it’s normal? It doesn’t seem right.
I would love to be able to free up space on the u it’s internal memory, but I’m not sure how to do this.
