Connectivity to IPhone AND Nex headset
Posted: Fri May 26, 2023 8:39 am
by Chopperbob
Folks,...
I seem not to be able to have the iPhone AND my NExx headset connected to the Zumo. They both show up on the Zumo but very seldom it works.
The iPhone is also connected to the headset, does that perhaps create a conflict?
Appreciate thoughts
Robert
Re: Connectivity to IPhone AND Nex headset
Posted: Fri May 26, 2023 12:19 pm
by Peobody
FWIW, I have never been able to get my Cardo to work when connected to both my iPhone and the XT. It keep it connected to the XT only.
One annoyance for me was that the XT would automatically prompt to play music from the phone. This got so annoying that I put the music on the XT and then disabled the music ("Media Audio") in the phones configuration on the XT.
Edit: I do not like to talk on the phone while I ride. It appears that I 'should" be able to answer incoming calls but my success at doing so has been mixed. I do care about fixing this. Seeing texts and missed calls on the XT is all I care about. I'll deal with them when I stop.
Posted: Fri May 26, 2023 2:02 pm
by Fallguy67
The best setup I came up with for my Sena headset was to pair it the the XT with a phone profile and then the XT to my iPhone, When I tried to pair my headset to the phone and to the XT (as BT device) I had several issues.
Posted: Tue May 30, 2023 11:43 am
by Chopperbob
Disconnected the "head-set" from the phone, now I am hearing the directions from the XT but no media/music from the phone although it is playing on the XT...
guess I need to experiment a bit more.....
