Page 1 of 4
Summary of tools to fix the trips on the XT
Posted: Thu Jun 01, 2023 8:39 pm
by FrankB
You can find this info also on: viewtopic.php?t=2301
This post is meant to draw your attention, to the other tools that meanwhile have become available.
Hex editor
Suited for people who dont want to install software and are not afraid to dive into hexadecimal numbers.
Pros: Works on any platform via https://hexed.it
Cons: Can do only one file at a time.
Info: See screenshot which byte to modify
Modify the trip on the XT
Suited for anybody
Pros: Works on the XT, so always available. Dont need a PC
Cons: Can do only one file a a time. Requires a few steps.
Info: https://www.ukgser.com/community/thread ... st-5242062
Java Program SetTripsToSaved
Suited for people that have Java installed, or are prepared to install Java.
Pros: Works on any platform, provided Java is installed. Can do multiple files at a time.
Cons: Need to install Java, some people have security concerns with Java.
Info: viewtopic.php?t=2301
Online Tool TripRepair
Suited for anybody
Pros: Works on any platform, no need to install anything.
Cons: Can do only one file a time.
Info: https://javawa.nl/triprepair.htm
Note: This tool creates a new file called nnnnnnnnn_mod.trip, that you should copy to the XT. Be sure to delete the original file on the XT, else the trip will be listed twice, which will be confusing.
Re: Summary of tools to fix the trips on the XT
Posted: Fri Jun 02, 2023 7:56 am
by Les
:shock: :shock:
Posted: Sat Jun 03, 2023 8:51 pm
by Oop North John
A couple of cons for the saving the active route on the XT are:
1) Definite - If you're not at the start of the route, and the XT knows where it is, then the starting point becomes your present location. Will mess up the distance / time to travel, but that sorts itself out once you start where the route should be starting from IYSWIM.
2) Probable - Faster roads rather than fastest route, will be mitigated by sensible use of via / waypoints.
Posted: Sat Jun 03, 2023 9:13 pm
by FrankB
Oop North John wrote: Sat Jun 03, 2023 8:51 pm 1) Definite - If you're not at the start of the route, and the XT knows where it is, then the starting point becomes your present location.
To overcome that you could: Enable the GPS Simulator. Set your location to where you want it. Start the route and then save the active route.
I agree that it's not something you like to do for a lot of trips. Still hoping for a Garmin solution...
Posted: Sat Jun 03, 2023 11:40 pm
by Peobody
I'm confused. Are you saying that modifying the .trip file breaks the ability to select the entry point of a route?
I don't believe that fixing trips by any of these methods does anything more that prevent the RUT issue. All other aggravations associated with recalcs remain.
Posted: Mon Jun 05, 2023 5:21 pm
by danham
Just used the online JavaWa tool and it works very well. On a Mac you do need to use Android File Transfer to be able to copy the Imported trip to your computer, then run the online tool, then drag the modified trip file back to your XT. Be sure to delete the unmodified file in the XT or Trip Planner will get confused by two versions with the same TRIP name, even if you modify the trip's file name when you save it. In other words, if the original trip is called HOME to Highway 81, when imported, the XT saves it as something like 1076539875.trip Even if you change that file name, it is still internally coded as HOME to Highway 81, so the original should be deleted before copying the modified file back to the XT. Also, if the modified trip fails to show up in the Saved window, power cycle (reboot) the XT and it should be there.
Posted: Fri Aug 11, 2023 11:43 am
by Apox
There is a video on how to fix the route on the device
Suited for anybody
Posted: Fri Aug 11, 2023 4:26 pm
by tombarrington
I know there are a number of threads on the RUT topic. Is there a sense of how this method fixes the problem? I've taken to being answering no to the recalculation prompt but it would be nice to go back to trusting that recalculation.
Posted: Fri Aug 11, 2023 5:14 pm
by Apox
tombarrington wrote: Fri Aug 11, 2023 4:26 pm
There is a pretty good post about it here. Post 10.
https://www.st-owners.com/forums/thread ... ol.183937/
Posted: Fri Aug 11, 2023 5:42 pm
by Peobody
The RUT problem is triggered by a recalculation but it is a different issue from recalculation results that modify pre-planned routes and produce illogical ones. We are still fighting that battle (eg: avoiding recalculation as much as possible).
