Page 1 of 3
Zumo XT has never worked in the cradle
Posted: Sun Jun 04, 2023 6:39 pm
by Tracer 900
I have mainly used my Zumo XT in the car, so I do know the charging works (via the car charger). However I cannot get the sat nav to charge in the cradle.
My multimeter indicates the two charge pins only give approx 5 mV (not 5 V).
I phoned Garmin Support and they immediately sent out a replacement power supply, but this replacement also gives approx 5 mV so the sat nav will not charge.
Does anyone have any ideas how I have gone wrong connecting two cables directly to a 12 volt battery? Surely both power supplies cannot be defective?
Thanks
Re: Zumo XT has never worked in the cradle
Posted: Sun Jun 04, 2023 7:17 pm
by Mzokk
Try a temporary connection to another battery? Easy access like a car battery?
Posted: Sun Jun 04, 2023 7:22 pm
by Tracer 900
The battery is putting out 12.8V, so I dont think its the problem.
Posted: Sun Jun 04, 2023 8:40 pm
by Stu
I'm not trying yo insult your inteligence here but you have got the connections the right way round haven't you?
Its been known for people to mix them up and not realise
Posted: Sun Jun 04, 2023 11:05 pm
by Fxwheels
If it works thru the charger, you have a power delivery problem in the cradle.
Many people complained about the pins not touching the cradle connectors good enough. I gave up and use a usb cable and 3.0 socket.
Posted: Mon Jun 05, 2023 6:43 pm
by Tracer 900
Stu wrote: Sun Jun 04, 2023 8:40 pm
Red to red, black to black. I was going to try reversing them, just to see, but I think I should ask Garmin Tech support first.
Posted: Mon Jun 05, 2023 6:46 pm
by Tracer 900
Fxwheels wrote: Sun Jun 04, 2023 11:05 pm
I tried using the usb socket on holiday in Spain/Portugal, but had lots of other problems with the sat nav (switching off, not finding the route, re-starting etc, etc) But I didnt use a 3.0 power supply.
Posted: Tue Jun 06, 2023 2:41 am
by Fxwheels
Tracer 900 wrote: Mon Jun 05, 2023 6:46 pm
Yes, anything less than 3.0 can do switching off and re-starting every so often.
In Spain I used the cradle connected to a BMW 12v socket on the bike (instead of directly to a battery as I didn't want to mess with the rented bike and still questionable result). What a nightmare it was...
Posted: Tue Jun 06, 2023 9:06 am
by pcdabbler
hook your XT up to the cradle and check your incoming 12v across the red/black wires, make sure its still 12v. Also check across your fuseholder, between the black wire and both sides to make sure theres not an issue there. Should be 12v on both sides with the fuse in on each blade.
Posted: Tue Jun 06, 2023 7:47 pm
by Tracer 900
Hi, thanks for replying, and trying to help, but I dont understand.
I have connected the black and red wires directly to the battery terminals (obviously black to positive, red to negative), with the zumo in place, I am getting 12.5V from the ends of the black/red wires.
But which fuse am I measuring across?
- Battery.jpg (349.35 KiB) Viewed 8039 times
