Add WP later.
Posted: Sat Jun 10, 2023 8:25 am
by Raf
I planned a trip with 9 routes and their tracks and various WPs. I forgot to transfer any WP from BC to Zumo. I corrected all routes with java program. Can I add now? Or delete everything and do everything again?
Thank.
Re: Add WP later.
Posted: Sat Jun 10, 2023 12:22 pm
by rbentnail
Using Base Camp, you can edit the routes that are on the XT. Make sure Garmin Express is NOT running, not even in the background. Open Base Camp, give it a minute. Plug your XT into your computer and give it time, it might take a minute. Click on the location of your routes in the XT (internal or user memory) section on the left and there they are! Re-route; add, delete or move points. Whatever you want to do.
Re: Add WP later.
Posted: Sat Jun 10, 2023 12:33 pm
by Peobody
@Raf, when you transfer a route from BaseCamp to the XT, all waypoints contained in it are recorded as Saved/Favourites waypoints when is is imported by the XT. Correcting the .trip file with the java program should not affect this. AFIAK, the only reason to transfer waypoints from BaseCamp is if you want them available as destinations in the Saved/Favourites list without importing their route. If that is what you need, doing so now should not affect the existing 'fixed' routes.
Re: Add WP later.
Posted: Sat Jun 10, 2023 1:42 pm
by Raf
These WPs are not along a route. They are places I could visit.
Another solution would be to import to the sd card. Then transfer to the Zumo
