Audio Output Button???
Posted: Tue Jul 25, 2023 9:16 pm
by BobsYourUncle
I want to use the speaker on my Zumo Roadtech 660. It works fine until I place the Zumo in the handlebar mounted power cradle, then it routes all sound through the wired headset. I am now using a helmet with no speakers, so I want the audio to go through the Zumo's speaker. According to the Zumo's Help menu, I should be able to go to the Menu page, choose Volume, which will let me see a Mixer button and an Audio Output button. Then I'm supposed to choose the Audio Output button. The problem is, there is no Audio Output button visible on that screen, only the Mixer button.
Does anyone know where the Audio Output button can be accessed? Or failing that, does anyone know how to make it so the sound goes through the Zumo's speaker even when it is plugged into the mounted power cradle on my handlebars?
Thanks!
Re: Audio Output Button???
Posted: Wed Jul 26, 2023 7:10 am
by kernowing
Not sure if it would work but you could try selecting Automobile mode rather than Motorcycle mode
Posted: Mon Jul 31, 2023 7:13 am
by waspanman
From memory the unit can tell if it's on the motorcycle or car mount, I think that's how it knows to use bluetooth or earpiece for the bike.
Although sometimes it takes a while to chose, but then my units are both around 12 years old.
Posted: Mon Jul 31, 2023 7:32 am
by kernowing
waspanman wrote: ↑Mon Jul 31, 2023 7:13 am
When I've been using my 660 in the car mount and I put it back on the bike it gives you the option to stay in car mode or switch to m/c mode. If you elected to keep it car mode, would the speaker stay active?
Posted: Mon Jul 31, 2023 1:04 pm
by waspanman
Usually mine starts with the speaker on, then switches to headset or earpiece, but as I have never tried your option, put me down as a don't know.
No I cannot in all conscience respond from a position of no knowledge, so out to the garage to test and sure enough a couple of seconds on speaker
then headset/earpiece, even in automobile mode.
If you really want audible output without earphones etc, what about a small speaker in the audio out jack, but remember the instructions will be broadcast to all, embarrassing in town, as my wife can testify, I put a Pyle audio system on her 750 Virago just so she could hear the instructions, she hated it
As I ride a Triumph Trophy SE, I have the option to route the sat nav audio through the bikes speakers, but haven't tried, as we have Shoei neotech 2
helmets with Sena SRL 2 comms fitted
