Planning (simple) point-to-point route in zumoXT or in Myrouteapp?
Posted: Sat Aug 05, 2023 6:17 pm
by Mikul
Hi, I did 8300 kilometers with Zumo XT in July around Europe. I planned Hotel-Hotel (simple) routes in myrouteapp and sent them to XT before starting the next day the trip. I didn't insert any waypoints, no stops, wouldn't it be easier to just enter the destination in Zumo XT and go? Now I ask myself this question, what do you think?
Re: Planning (simple) point-to-point route in zumoXT or in Myrouteapp?
Posted: Sat Aug 05, 2023 11:16 pm
by Fxwheels
If you don't mind the route it gives you and works for you, then why not.
But, if you want to have a specific roads you want to ride thru, then you need shaping points.
Posted: Sun Aug 06, 2023 3:53 am
by rbentnail
https://www.fjriders.com/forums/viewtop ... lit=screen
Another forum where I described how to make a route on the device itself. I described the 595 model specifically but the XT is the same. Starts on page 2.
Posted: Sun Aug 06, 2023 12:33 pm
by lkraus
Start using the XT for your normal, everyday, local trips. It will route you to the destination, but I think you will quickly see that it does not pick roads you would select using your local knowledge. The routes will not be the quickest, nor shortest, nor efficient at avoiding traffic delays.
After using the XT locally, I have no confidence in longer routes it creates until I've checked them against Basecamp or Google Maps.
Posted: Sun Aug 06, 2023 3:17 pm
by danham
lkraus wrote: ↑Sun Aug 06, 2023 12:33 pm
To this good advice, I'd add that if the XT recalculates a route it chose (as opposed to pre-planned by you), it can really butcher your trip. This can also happen with a pre-planned route, but the problem is much easier to deal with if you have deployed shaping points and uploaded a track of your route to display along with it -- none of which can really be done if the XT does the routing for you.
Posted: Sun Aug 06, 2023 5:28 pm
by Mikul
Thanks for all the answers, I am an experienced Gamin user for many years, I can use Mapsurce, Basecamp and Myrouteapp without any problems. Now, after returning from the 2023 trip and planning 17 routes in each of the next hotels, I come to the conclusion that I did not need to log in to MRA because it was enough to enter the address or name of the next hotel in XT (or Drive) check if route is inwith my preferences (possibly add Shaping Points) and go.
The last two routes designed in MRA, before setting off I compared them with those made in ZUMO, they were the same. And now I think that I could devote the time spent at the MRA to sightseeing, it was a lot because the trip lasted 34 days and we did 8400 km with my wife.
PS.
do you use the nearest entry point for routes designed in MRA? The routes were designed point-to-point (the exact addresses of the Hotel) without shifting in the direction of travel, As I did and only in Paris it did not work as I expected.
EDIT this may be important, I work on firmware 2.90
, I have the latest maps.
