Synchronisation with Explore Cloud is not working with new Firmware 4.30
Posted: Thu Aug 24, 2023 9:22 pm
by lpop
Today i installed the new Firmware 4.30. Also the Tread App on the iPhone got a new update.
Now the Synchronisation is not working anymore.
New Tracks from the explorere Cloud will not be transfered to the XT2.
Does anybody has the same problem?
Thx lpop
Re: Synchronisation with Explore Cloud is not working with new Firmware 4.30
Posted: Fri Aug 25, 2023 12:47 pm
by dhwalt
Try a full reset on the XT2. You will have to re-enter your preferences but this solved a lot of my issues following the update.
Dave
Posted: Fri Aug 25, 2023 8:34 pm
by lpop
A full reset didn‘t help. Also a rollback from 4.30 to 4.00 didn‘t help. Seems the Tread App with version 2.07.33 is the problem.
Posted: Wed Aug 30, 2023 4:43 pm
by turbo19
There is a Tread update coming soon (Garmin words).
Meanwhile you can install 2.06.22 version by this web (june "stable" versión).
https://apkcombo.com/es/tread/com.garmi ... app.tread/
Regards,
Posted: Sat Sep 16, 2023 2:43 pm
by jures
No issues with me, also with iphone
Posted: Fri Nov 29, 2024 3:44 am
by PedroBrennan
Meanwhile, you can install version 2.06.22 using this website.
https://gamemodfree.com/games/aksi
