Zumo XT Fails to Calculate & Display Route Segment Info
Posted: Mon Aug 28, 2023 7:38 pm
Am wondering if anyone else has seen this issue & if there is a known work around / fix
When passing a Via point, my XT will sometimes popup a display on the right of the screen with some route info similar to this
It does not seem to do it for every Via point, why it does for some & not others I do not know?
The issue I see is sometimes it seems to fails to calculate & all I see is a blue spinning disc
When the route info is displayed correctly the popup window closes automatically after a few seconds which is fine.
I would not find it a problem if the popup window with the blue spinning disc closed automatically but it does not, it remains persistent & requires to be closed manually via the X
It would be nice to know what is causing the calculations to fail or if there is a way to prevent the segment calculations poping up?
