Page 1 of 3
Garmin withdraw map updates for older devices
Posted: Fri Nov 03, 2023 6:55 am
by sussamb
Re: Garmin withdraw map updates for older devices
Posted: Fri Nov 03, 2023 8:01 am
by kernowing
The 660LM is not mentioned, would that be covered by the 665LM GPS Navigator?
Posted: Fri Nov 03, 2023 10:20 am
by sussamb
If you enter 660lm in the box you'll be told it doesn't apply to that model
Posted: Fri Nov 03, 2023 10:11 pm
by electro_handyman
I had a feeling it would be coming sooner than later for my 550..... not surprised one bit. Will continue with OSM maps.
Posted: Sat Nov 04, 2023 2:27 am
by MSTOCK27370
electro_handyman wrote: ↑Fri Nov 03, 2023 10:11 pm
Do the OSM maps fix the problem with the new Garmin maps where the street names look like this C......... D....
Posted: Sat Nov 04, 2023 11:19 pm
by electro_handyman
The Garmin version I have is 2023.10 and they are abbreviated, my OSM I have is dated 2021 and they are not abbreviated.
Posted: Tue Nov 07, 2023 5:10 am
by hammer
What are osm maps? I can't update my 665.
Strange 660 still gets updates but not 665.
Posted: Tue Nov 07, 2023 6:52 am
by sussamb
Open Street Mapping ... Google it and you'll find numerous providers of Garmin compatible maps
Posted: Tue Nov 07, 2023 1:13 pm
by lkraus
hammer wrote: ↑Tue Nov 07, 2023 5:10 am
There are links to many sources here:
https://wiki.openstreetmap.org/wiki/OSM ... n/Download
Scroll down to the region you need, pick a source that offers
routable maps, preferably with an installer compatible with your computer.
Although the underlying OSM data is the same, the maps can vary in appearance, detail, and coloring, so you may want to try several to see which one works best for you. Have only one active routable map on your Zumo at a time.
Posted: Tue Nov 07, 2023 10:16 pm
by electro_handyman
Also make sure that you use the same map on your PC when making the routes... it will make your life a whole lot easier.
