RAM handlebar mount
Posted: Fri Dec 22, 2023 4:10 pm
by twowheelstom
I'm going to try this type of handlebar mount instead of the U clamp type on my 1" bars
8-)
Re: RAM handlebar mount
Posted: Fri Dec 22, 2023 10:11 pm
by MSTOCK27370
Looks nice - nicer than the U-Clamp. Never seen that one before.
Posted: Thu Dec 28, 2023 2:59 pm
by twowheelstom
the pieces in the 1" ball kit, with spacers for smaller bars
8-)
Posted: Thu Dec 28, 2023 8:58 pm
by twowheelstom
I used the supplied rubber tape in the kit under the mount, to keep the mount from sliding around the bar,
and put electrical tape under the nuts to keep them from falling out before they got tightened up
the red bag is my wife's old purse she didn't want anymore, now my purse, its secured to windshield support bolts
8-)
Posted: Fri Dec 29, 2023 2:14 pm
by rbentnail
That looks pretty good! I've never been a fan of the u-bolt mounts.
Posted: Sat Mar 23, 2024 4:17 pm
by bicyclenut
If you wanted a chrome verson of that to match bars and maybe bike, Tackform makes chrome mounts similar, but better built with all metal, 20mm balls that might work. You would still need a black AMPS mount for GPS but that would be behind the chrome clamp and arm. The web link shows teh phone mount but you can mix and match parts and many come in chrome finishes.
https://www.tackform.com/products/chrom ... e-dampener
Posted: Fri Nov 15, 2024 7:02 pm
by twowheelstom
I made a to-do list for this winter for the stored kawasaki vulcan 800 cruiser motorcycle, and on the list is to install the XT cable mount and wiring, thinking of connecting to the always hot accessory leads in the headlight bucket, it would be more difficult for me to run the wire under the gas tank and the seat, the headlight is an easy on-easy off item on the bike. 8-)
Posted: Fri Nov 15, 2024 10:41 pm
by rbentnail
twowheelstom wrote: Fri Nov 15, 2024 7:02 pm I made a to-do list for this winter for the stored kawasaki vulcan 800 cruiser motorcycle, and on the list is to install the XT cable mount and wiring, thinking of connecting to the always hot accessory leads in the headlight bucket, it would be more difficult for me to run the wire under the gas tank and the seat, the headlight is an easy on-easy off item on the bike. 8-)
I had an '03 800B and can verify- the connections in the headlight bucket are SIGNIFICANTLY easier to access.
