Page 1 of 2
What XT case to get
Posted: Fri Feb 23, 2024 8:15 am
by twowheelstom
What carrying case or no case are you guys using for the XT ?
Re: What XT case to get
Posted: Fri Feb 23, 2024 11:08 am
by rbentnail
I measured the unit and bought a generic one from Amazon. I don't think I used it a single time last year, and maybe not the year before. It just rides around in my top case when traveling. Turns out for me it was a waste of money.
Posted: Fri Feb 23, 2024 2:42 pm
by twowheelstom
so when travelling and stopping, do you remove the XT and place it somewhere?
Posted: Fri Feb 23, 2024 2:54 pm
by lkraus
I never used a case for my 590 or for the first couple years with my XT. A Zumo is pretty rugged on its own, and I kept it in a pocket or pannier when not mounted. A separate case just seems like one more item to deal with and store.
When I bought a 3D printer last year, I printed a "bumper" case out of a soft plastic (95A TPU) that provides some drop protection without being bulky. It also has a hole for a lanyard, which comes in handy when my hands are full, just hang it from a wrist. I also slip the loop over the Ram mount in case the mount releases unexpectedly. I printed this just for fun, to use the printer, but the cushioning also makes it easier to grip. A Google search for "Zumo XT bumper case" will find a few people selling these for about $20-25 USD.
- XT bumper case.jpg (82.08 KiB) Viewed 2784 times
Posted: Fri Feb 23, 2024 9:54 pm
by rbentnail
twowheelstom wrote: Fri Feb 23, 2024 2:42 pm
I used to. The travel pack on my rear seat has external pockets and I'd just drop it in there. I've since installed a Motopumps lock so now I just put the unit to sleep when I stop and turn it back on later. It stays in the mount all day, I remove it at night.
https://www.motopumps.com/shop/zumo-xt-security-lock
Posted: Sun Feb 25, 2024 4:00 am
Yes. Always. I usually have to open the top box anyway, so gloves, satnav, riding glasses all go in there while I am gone. If panniers are empty, helmet goes into one of those.
Posted: Sun Feb 25, 2024 3:40 pm
by VFRcanada
I have this
https://www.amazon.ca/gp/product/B002II ... UTF8&psc=1 but I never use it. It's a perfect fit. It just sits on my computer desk.
Posted: Sun Feb 25, 2024 8:32 pm
by rbentnail
Looks identical to mine. I use it for postage stamps, usb thumb drive, SD cards for the XT, earbud tips, etc. when traveling so I can find the small things easily.
Posted: Sun Feb 25, 2024 9:14 pm
by twowheelstom
will the XT fit in your case along with all those?
Posted: Mon Feb 26, 2024 1:55 am
by Peobody
I found an old cassette tape case that ended up being the perfect size to hold the XT and it cable. That case does not travel with me though. When I stop, I place the XT into either a locked fairing pocket, my locked trunk along my helmet and gloves, or my jacket pocket.
