Express v7.20
Posted: Fri Mar 01, 2024 6:30 pm
by Peobody
I just saw an announcement on the garmin.com forum that Express v7.20 was released yesterday. There were also two posts about v7.20. One was a failure to synch with Garmin Connect. The other alluded to problems with v7.20 but does not mention anything specific. I have not upgraded to it.
v7.20 release notes:
  • Fixed the progress bar going over 100% for certain map updates.
  • Made an improvement for handling an exception that could cause Express to freeze on a grey screen.
  • Resolved an issue with map updates failing to install to the computer.
  • Resolved a server error that could occur for marine chart updates.
  • Resolved an exception that could occur when prompting a user to do a restart after a software update.
  • Resolved an issue with Express not updating the date and time on a vivosmart 4.
  • Other minor bug fixes and improvements.
Re: Express v7.20
Posted: Sun Mar 03, 2024 1:55 pm
by twowheelstom
Updated to Express v7.20.0.0
all went smoothly
thanks for the heads up
8-)
Re: Express v7.20
Posted: Tue Mar 05, 2024 9:10 pm
by raza
New GE V7.20.1.0
Re: Express v7.20
Posted: Tue Mar 05, 2024 9:54 pm
by Peobody
raza wrote: Tue Mar 05, 2024 9:10 pmNew GE V7.20.1.0
That was fast by Garmin.
Release notes for v7.20.1.0
- Resolved an issue with voucher codes returning as invalid when redeemed.
- Resolved an issue with sync failures occurring for the vivofit 4.
Unfortunately there is nothing to indicate a resolution to problems reported with map installation to PC.
