Partial screen freeze up.
Posted: Sun Mar 10, 2024 2:38 pm
by Purrtec
My 396 speed icon and trip arrival time freezes up intermittently. Is there a way to reboot the system?
Re: Partial screen freeze up.
Posted: Tue Mar 12, 2024 10:18 pm
Sorry I do not have your Zumo model
But on the XT there is an option under Settings ->Device ->Reset
On the 590 and 595 and XT there is an option in a hidden system menu.
View Map -> Speed button -> Long press the circular speed (10 secs) -> Clear All User Data
Worth a try ?
Posted: Tue Mar 12, 2024 11:49 pm
by Purrtec
Thanks, will give it a try and let you know if it works.
Posted: Tue Mar 26, 2024 12:38 pm
Did this work @Purrtec ?
Or have you found a way that does work ?
Posted: Tue Mar 26, 2024 2:51 pm
by Purrtec
To,jfheath,
My 396 has the same settings as the XT. I did the reset and so far I haven’t had a freeze up, but it was an intermittent problem.
It seems to have worked to this point. I will repost if it happens again. Thank you, purrtec.
