Listening to Audio Books on Zumo 595
Posted: Tue Mar 26, 2024 9:06 pm
by carolinarider09
Is there a way to listen to "audio books" on the 595? The audio books I have been listening to on the 665 are in an AAX format. I download them from Audible.
I would like to keep listening to them.
Thanks.
Re: Listening to Audio Books on Zumo 595
Posted: Tue Mar 26, 2024 10:07 pm
by lkraus
The 595 only plays .mp3 files. Try a search for "convert .aax to .mp3" to find conversion methods.
But it is possible Audible uses copy protection that prevents conversion.
Posted: Wed Mar 27, 2024 12:02 am
by carolinarider09
I thought I'd probably have to get a "converter". Did a search and found this one. Since I have a MacBook, it would work.
Only problem is the cost. But I can download some books in advance and probably get enough for one year.
https://www.tunepat.com/audiobook-converter.html
Posted: Wed Mar 27, 2024 12:59 am
by lkraus
I don't use Audible, but this free program looks pretty good:
https://openaudible.org/
Posted: Fri Apr 12, 2024 9:39 pm
by carolinarider09
I missed your post. That looks like a very cool and reliable program. I will investigate and probably use. Thanks!!!!!
