Routing Error??
Locked
HMA14
Routing Error??
Post by HMA14 »
When I power up Zumo, I'm getting the error in the pic, also:"Cannot unlock maps". When I search for a place, I get "Cannot find search results for xxx". This just started. What is going on?
MotoToph
Has liked: 32 times
Been liked: 16 times
Re: Routing Error??
Post by MotoToph »
Did a map update fail? Try plugging into Express and updating it.
ZUMO XT
K1600GT
HMA14
Re: Routing Error??
Post by HMA14 »
Yes. About a week ago my PC crashed while it was updating. I suspected this to be the issue. I have connected to GE several times. It says "You're up to date" and "Software Version: 6.60".....
Re: Routing Error??
Check in Settings, Map&Vehicle, myMaps to see what is shown and that a valid map is selected.
If nothing choose the Reinstall option in Express
HMA14
Re: Routing Error??
Post by HMA14 »
That worked. Thanks.
HMA14
Re: Routing Error??
Post by HMA14 »
Edit: The maps looked good and were selected. I reinstalled and it worked.
Re: Routing Error??
Great, I'll close this thread
Locked
