XT Stand
Posted: Sat Aug 03, 2024 1:50 pm
by waspanman
Bored with trigging the XT up on books when connected, off to the shed and a few bits of scrap and a bit of lathe turning later.......suits me sir
Re: XT Stand
Posted: Sat Aug 03, 2024 2:54 pm
by Peobody
That is impressive!
Re: XT Stand
Posted: Sat Aug 03, 2024 3:44 pm
by waspanman
Thank you, with the USB cables getting even shorter (latest version 50cm or 19 inches long) it's a job to stop the unit sliding off the desk, (no wifi in our house)
Re: XT Stand
Posted: Sat Aug 03, 2024 5:40 pm
by Peobody
waspanman wrote: ↑Sat Aug 03, 2024 3:44 pm
I hear you. I use a laptop on a stand that has an acrylic shelf that the laptop sits on. The shelf is angled downward towards the front. With my previous laptop, my XT could sit securely on the shelf behind the laptop. That space is narrow but the laptop hinge was at the perfect height to hold the XT in place. My new laptop does not have the hinge protrusion at the right height resulting in the XT being susceptible to falling with the slightest bump. Your post has me thinking hard about an alternative spot for it.
Re: XT Stand
Posted: Sat Aug 03, 2024 6:31 pm
by waspanman
After I made this, I checked out 17mm balls on the net, (I made my own from nylon 66 bar) there are lots of them and they will fit straight into the XT car mount.
Re: XT Stand
Posted: Sun Aug 04, 2024 1:07 pm
by lkraus
Nice work on the stand, it has a nice clean look.
If I'm not using the screen (most file transfers, updates), I either lay the XT on its face or use the flat bottom of its
3D printed bumper case to stand it on my desk. The soft flexible plastic also provides a better grip and protection if I still manage to drop the Zumo.
If I'm actually using the screen, a
cell phone stand provides additional stability.
Many more models for 3D printing can be found through
thangs.com, including some that use the regular mount, with or without the power pins.
Re: XT Stand
Posted: Sun Aug 04, 2024 8:36 pm
by Stu
Nice work
I just use the car mount stuck to my desk!
