NT or NTU?
Posted: Mon Nov 26, 2018 3:17 pm
by Fitz
Possibly a dim question but what's the difference between an "NT" map and an "NTU" map?
Thanks!
Re: NT or NTU?
Posted: Mon Nov 26, 2018 3:38 pm
by sussamb
NTU includes certain characters/alphabets not in the NT map, U stands for Unicode.
Unicode version can display cyrillic and some other languages characters and signs (like greek, polish,latvian etc)
Re: NT or NTU?
Posted: Tue Nov 27, 2018 12:12 pm
by Fitz
Thanks!
Re: NT or NTU?
Posted: Mon Jun 10, 2019 5:29 pm
by tonkatoy001
Not sure if this is correct or not but my Zumo550 seems to use the NT maps and the 395 uses the NTU maps. I have both sets of maps installed on Basecamp.
I can create a route on the NTU maps on Basecamp and use it on the 550 but it always recalculates because the same maps are not installed. Not caused me a problem so far tho'
Tonka
Re: NT or NTU?
Posted: Mon Jun 10, 2019 7:45 pm
by sussamb
Correct, earlier ones use NT maps, later ones NTU.
Re: NT or NTU?
Posted: Sat Jul 18, 2020 2:29 am
by danielb
Can the XT read unlocked/free NT maps?
Re: NT or NTU?
Posted: Sat Jul 18, 2020 6:41 am
by sussamb
I've partly answered this elsewhere, but to amplify there are no 'free' NT maps unless you are talking about pirated ones, which we won't discuss on this site. CN maps from other devices are locked to the device, unless they were supplied on a card from Garmin in which case the card can be used in any device.
Re: NT or NTU?
Posted: Sat Jul 18, 2020 6:50 am
by danielb
No. Not pirated maps.
Sources of maps are from here:
NT Maps
https://buy.garmin.com/en-US/US/p/89538
Free Maps
http://nightrider.info
Re: NT or NTU?
Posted: Sat Jul 18, 2020 2:06 pm
by sussamb
Then the Garmin card will work but not sure about the other maps as not used them but they should be fine looking at the description.
