Brand new user - Hello
Posted: Thu Nov 29, 2018 9:26 pm
by PJZumo590
Hello from Scotland!
I've just unboxed a used 590LM. I'm really pleased with the feel, finish and accessories. I just tried to update it but the wifi where I am just now is rubbish and so everything hung. I switched it off and I'll do this when I get home on Monday. Having interrupted the update, the unit seems to no longer have any maps onboard but I think this will be sorted when I've a good wifi service to update through.
Re: Brand new user - Hello
Posted: Fri Nov 30, 2018 9:53 am
by tojjer
Hello and welcome buddy
Posted: Fri Nov 30, 2018 11:51 am
by sussamb
Better if you can to not use wi-fi to update.
Posted: Fri Nov 30, 2018 1:14 pm
by kernowing
Welcome to the forum PJ.
Posted: Fri Nov 30, 2018 1:46 pm
by Wingstyle
Welcome PJ. I think you will find this forum very informative.
Posted: Fri Nov 30, 2018 9:47 pm
by Stu
Posted: Sun Dec 02, 2018 8:57 pm
by Sleuth
Welcome to the forum, hope you enjoy your GPS.
I concur it is better to use a computer when updating - if for no other reason, power. If the battery fails while performing an update - you are totally stuffed.
Best regards
Sleuth
Posted: Sun Dec 02, 2018 11:38 pm
by rbentnail
Sleuth wrote: ↑Sun Dec 02, 2018 8:57 pm
Best regards
Sleuth
^This^. 590 batteries aren't known for their longevity even if you have "fixed" them. See here ->
viewtopic.php?f=12&t=2. Also, don't make the mistake I did long ago: when using a computer, go to your Settings/Power and select Never in the sections about how long until your computer turns off and Sleeps. Don't want that thing shutting off in the middle of a 4 hr download!
Posted: Mon Dec 03, 2018 2:55 pm
by Sleuth
rbentnail wrote: ↑Sun Dec 02, 2018 11:38 pm
...^This^. 590 batteries aren't known for their longevity even if you have "fixed" them. See here ->
viewtopic.php?f=12&t=2. ...
I downloaded my routes into BaseCamp, and updated the Safety Cameras (Speed Cameras / Gift to the Government / or whatever) and this morning the battery was "low".
However as long as it is connected to power (either by mount or by computer it should not be a major issue. He said hopefully!
