660 External antenna socket name ?
Posted: Sun Sep 22, 2024 6:40 am
by NeilP
Just been wondering about fitting an external antenna on my 660.
I discovered the socket on the side after XX years owning it.
I had expected to need to drill holes in the case and solder on a BNC pigtail.. but on preparing to open it up I found the socket.
I see MCX-BNC Adapters, but the pictures make me think that is the wrong plug for that socket.
Anyone know for sure ?
Re: 660 External antenna socket name ?
Posted: Sun Sep 22, 2024 8:04 am
by kernowing
I have one of those external antennas here (somewhere). I'll look it out and see if I can shed any light on the subject.
Do you already have an external antenna to use on your Z660?
Posted: Sun Sep 22, 2024 8:35 am
by NeilP
Thank you
Yes, I have various GPS external antennas, all with BNC fittings
The MCX type adapters I have seen look more like the mini ones that are directly on the PCB.
The one on the side looks different.
Posted: Sun Sep 22, 2024 9:59 am
by kernowing
Photos of Garmin Antenna and plug.
Z660 plug.jpg (235.29 KiB) Viewed 7276 times
Z660 Antenna.jpg (378.8 KiB) Viewed 7276 times
Posted: Sun Sep 22, 2024 10:21 am
by NeilP
Thank you
yes it does look like an MCX
https://en.wikipedia.org/wiki/MCX_connector
