Glad to be a new member.
Mikey
Has liked: 92 times
Been liked: 11 times
Australia
Post by Mikey »
Greeting all members, from Mikey.
I enjoy using GPS's and have used them (2 Garmins) on my past 6 bikes and others in my cars. I purchased an XT 18 months or so ago and have been disappointed that I cannot get it to work well. Sometimes I think I have it sorted, but 'no', of it goes on its merry way, doing what it wants to do.
I also have the original Garmin Nav V that came with my BMW (R1250RS) but I have given most attention to the XT, trying to get its cooperation and be the great GPS I imagine it should be.
I will probably have many basic questions and will do my best to read relevant previous posts.
BMW R1250RS
Has liked: 431 times
Been liked: 949 times
Re: Glad to be a new member.
Hello and Welcome @Mikey
Read this first chapter for starters. viewtopic.php?t=1464
The XT and the NavV are broadly similar, but you have to know how to talk to the XT.
How do you plan routes ? What software
Do you use routes or tracks - do you know the difference ?
You have to learn XT rules, like 'Faster' does not mean 'find a quick way'. And some other weird terms that defy logic.
We can certainly help you master it if you give us some basic info about how you have used your NavV
For example. I tend to use Basecamp or sometimes MyRouteApp for planning.
I create routes with via points and shaping points
I always create a track of the route and display that as well as the route.
Has liked: 147 times
Been liked: 453 times
Greeting @Mikey. Welcome to the forum. The XT is aggravating but it can indeed be tamed.
jfheath wrote: Thu Dec 05, 2024 12:54 am For example. I tend to use Basecamp or sometimes MyRouteApp for planning.
Me too, except for sometimes using MyRouteApp.
A great thing about the forums here is there are a lot of differing views. Well, maybe that is not great for someone who just wants to be told what to do and how to do it. OTOH, it's great if you want to learn your options and then pick the one that works best for you.
ZFtracker
Has liked: 17 times
Been liked: 31 times
Post by ZFtracker »
Welcome to the forum, @Mikey.
There's lots of good info here, and some very helpful folks.
Zumo 590
Montana 610
Drive 60
inReach Mini
Mikey
Has liked: 92 times
Australia
Post by Mikey »
Thanks again for your welcomes and advice, and special thanks to jfheath for assembling a wealth of technical information on Basecamp and navigators, a remarkable effort. I have made good progress in my learning.
Jfheath asked: ‘How do you plan routes ? What software’.
I have used Google Maps mainly, in a clumsy/clunky way to outline a route. Written down various aspects (pencil and paper), very unsophisticated! Sometimes I have broken the route or trip into parts so that Google Maps gave me the information, distances, time intervals etc. I have also worked directly on the XT, which has had a 90% failure rate, but prospects for success look bright now with my increasing knowledge of BC.
Mikey.
BMW R1250RS
