Screenshot question...
Posted: Sat Dec 07, 2024 10:41 pm
by Peobody
Is there a way to delete XT screenshot files from within the XT, or can that only be done with a file explorer?
Re: Screenshot question...
Posted: Sun Dec 08, 2024 1:29 pm
by Rofor
No, as far as i know only possible via a file explorer - 'normal' full reset also does not delete them! Maybe the only solution to do this without a file explorer is a via flashing the firmware with the hidden start-up menu, but i can't say for sure as i've never used this...
