Importing GPX into Tread - greyed out
Posted: Mon Jan 20, 2025 11:54 am
by stefzn
I'm having issues with importing a GPX file into the Tread app, I've never had this happen before.
I made a route on calimoto's website and I exported it as GPX, transferred that GPX to my iPhone and when I click "Share" the Tread app is not there, I was like okay let me try directly from the Tread app.
Open Tread -> Saved -> Three Dots -> Import Data (GPX) and the GPX file in my File Manager is greyed out.
Anyone dealing with this?
This is my route
https://drive.google.com/file/d/1zChuxp ... sp=sharing
Re: Importing GPX into Tread - greyed out
Posted: Mon Jan 20, 2025 6:46 pm
by Oop North John
I email gpx files, produced in Basecamp, and then select the attachment to open a,d my Android phone asks me what app to use. I select Tread and it opens up ok. Might that work for you?
Posted: Mon Jan 20, 2025 10:28 pm
by stefzn
Oop North John wrote: ↑Mon Jan 20, 2025 6:46 pm
Try my GPX, see if it works for you.
Posted: Tue Jan 21, 2025 1:26 pm
by Oop North John
Downloaded your gpx to my phone. Went to open it and Tread was one option. See below for what I see it showing.
Hope this helps.
Posted: Tue Jan 21, 2025 9:47 pm
by stefzn
Oop North John wrote: ↑Tue Jan 21, 2025 1:26 pm
Hope this helps.
So it's an iPhone bug then.
Posted: Wed Jan 22, 2025 9:24 am
by Oop North John
stefzn wrote: ↑Tue Jan 21, 2025 9:47 pm
The easy bit is working out what the bug is, a whole exponential extra level of difficulty in getting Garmin to acknowledge it and fix it.
Be aware that if you do report it they'll probably want a video of the problem occurring.
Posted: Sun Mar 23, 2025 9:45 pm
by vigo
Importing with Tread from Google drive worked as a charm. Now it is broken and the gpx file is greyed out, unselectable. Workaround is to enter google drive and the share the gpx file with Tread. Hope it helps.
