System Files
Posted: Thu Feb 06, 2025 9:13 am
by wingrider.steve
I no longer seem to be able to access the system files on my zumo XT or my old Nuvi 2360 when they are hooked up to the PC.
In particular I want to access the xml file on my Nuvi.
Has something been changed by Garmin to block access to these files?
Re: System Files
Posted: Thu Feb 06, 2025 7:55 pm
by sussamb
Do you see any files or nothing at all? The .xml file should be in your Garmin folder.
Re: System Files
Posted: Thu Feb 06, 2025 8:55 pm
by lkraus
To see the .System files on the XT you need to enable that option on the Diagnostics Page.
View Map → Tap Speed → Hold on Speed for about 8 seconds → Configuration and Settings → MTP settings → Show .System
Re: System Files
Posted: Fri Feb 07, 2025 12:14 pm
by wingrider.steve
That's the problem, I don't get Configuration & Settings on the Nuvi diagnostics page.
Re: System Files
Posted: Fri Feb 07, 2025 12:17 pm
by wingrider.steve
sussamb wrote: Thu Feb 06, 2025 7:55 pm Do you see any files or nothing at all? The .xml file should be in your Garmin folder.
I see lots of folders when I hook up the Nuvi including the Garmin folder but the xml file is nowhere to be seen.
Re: System Files
Posted: Fri Feb 07, 2025 12:27 pm
by lkraus
You might try using Mass Storage mode, if your Nuvi has that option, and then setting your file manager to view hidden files/folders.
OR doing a Google search for keywords including:
  • Nuvi ####
  • hidden
  • system
  • diagnostics
Re: System Files
Posted: Fri Feb 07, 2025 6:56 pm
by sussamb
wingrider.steve wrote: Fri Feb 07, 2025 12:17 pm
Well it should be in the Garmin folder. Do you have Windows set to show system AND hidden files, two separate settings?
