Modifying Routes using the ZumoXT2 by itself.
Posted: Wed Feb 12, 2025 11:43 pm
Hi
Iv'e been trying to teach myself how to modify an already planned route on the XT2. I've have been using the instruction provided by Garmin it's self on the following Website.
How to Manually Shape a Route on a zūmo® XT2
https://support.garmin.com/en-AU/?faq=I ... tab=topics
Garmin instructions are not very clear, and I left this a feedback on their help page .... "On a Zumo XT2 the Route needs to be running first in order for the Shape Route function to be available once a location has been touched on the screen. This is not mentioned on this page's instructions.
Also under the "These Changes can be Saved to Your Route for Future Use by Going Into Route Planner" at step 5 where it says Type the desired name for the route, then touch Done" The virtual keyboard never shows after touching the save icon. Only a list of previously saved routes appear and there is no option to save the newly Shaped Route"
Has anyone else been able to save a modified route, as a new route, using the Garmin help page instructions?
Thanks.
Thanks.
