ZUMO 660 SD Card File Transfer & Update (16GB to 32GB)
Posted: Sat Feb 15, 2025 7:15 pm
I have a Zumo 665 and a Zumo 660. The following question regards the 660 but it might also relate to my 665.
I connected the Zumo 660 to my computer and had Garmin Mapinstall up and running. I was sort of playing around but was surprised when the program told me I could load the newest Garmin maps on the device. The only issue, it said, was that the Maps had to go on the SD Card and my 16 MB SD card was too small. It said I would have to load a 32 MB card to get the newest maps on the 660.
So, I got a 32GB memory card and I copied all the files from the 16GB card (this included Books and Music) to a folder on my MacBook and then removed the 16GB micro SD card from my card reader and inserted a freshly formatted 32GB micro SD card.
I then copied all the files from the folder to the 32GB SD Card. Once the copying was finished I dismounted the SD card from the computers card reader/holder and inserted it into the Garmin 660. Turned the Garmin on and..... It started up and seemed to work (I did not check the maps for the right version it was 2025.20).
No issues with map being shown but I then tired to find a book. No books were there (although six were copied to the SD card. Also there was no music shown. There were about 26 folders each folder containing between 12 and 16 songs.
Ok, the question is, should you be able to clone an SD card the way I did?
If not, is there a process to clone the 16GB SD card so that the information will be available on the 32GB SD Card?
Thanks.
Thanks.
