Unorthodox & Temporary Installation
Posted: Tue Jan 01, 2019 3:27 am
by m185945
My intent is to keep my zumo 590LM powered up during all times that the motorcycle ignition switch is on.
The reasons for asking the following question is because:
• my zumo 590LM battery is so old that the charge only lasts about one hour
• I cannot afford a battery replacement
• I will be riding about 8 hours per day
The following discussion excludes Garmin part number: 010-12110-00 because the motorcycle I will be riding will be a rental/hire. In other words, I am proposing a temporary solution and I cannot afford the 010-12110-00. I already have 010-12110-00 on my bike, but do not want to remove it for a temporary transfer to a rental/hire bike.
Proposed Configuration in detail:
• Hella power receptacle (female) on motorcycle
• Hella power plug (male) inserted into above
• Cable from above to inside of tank bag
• End of above cable includes standard cigarette lighter receptacle (female)
• Standard cigarette lighter plug (male) inserted into above
• Cable from above routed outside of tank bag to zumo 590 on a RAM mount (not 010-12110-00)
• End of above cable is USB Micro and will be connected to the USB Micro port on the zumo 590LM (it is understood this connection will make the 590 vulnerable to water).
Will the above cabling configuration keep the zumo 590LM powered on at all times the motorcycle ignition is on?
Besides exposing the zumo 590LM to water do you see any adverse consequences for the above cabling configuration?
I thank you in advance for your cooperation.
Re: Unorthodox & Temporary Installation
Posted: Tue Jan 01, 2019 9:52 am
by Stu
590 charge issues viewtopic.php?f=12&t=2 :)
Posted: Tue Jan 01, 2019 2:50 pm
by rbentnail
Stu gives a good improvement but it's not a day-long solution.
I think that configuration will work fine particularly b/c the cigareete socket is (as you describe) inside the tank bag. I'd change one minor thing tho- instead of a cigarette lighter socket to usb cable I'd use a 2 usb adapter in the socket and use standard usb cables. Small velcro straps are your friend for such things so longer cables can be used (reasoning follows). Then I could keep my phone charged inside the tank bag as well, charge my mp3 at stops, etc. Plus, with a simple 2 usb port wall outlet, the same cables could be used in a motel room as well, hence the need for longer-ish cables.
Look for something like this, pay attention to your usb power needs of your devices.
usb adapter.JPG (25.38 KiB) Viewed 25351 times
Posted: Tue Jan 01, 2019 3:08 pm
by mzeist
You can indeed use USB to power the Zumo, but the USB connector is quite fragile, so if you choose this way maybe use an angled connector to remove some of the strain from the Zumo USB connector (like this one: https://buy.garmin.com/en-US/US/p/pn/010-12110-02)
My Zumo came with an automotive mount beside the motor mount, if you the automotive mount than using that might be a beter option then using USB.
Posted: Tue Jan 01, 2019 7:41 pm
by advnzer
are you sure the rental motorcycle has no provision for a gps?I would think that most hire bikes would have gps for hire too and are therefore gps ready???Or at least set up for powering some device?
Posted: Tue Jan 01, 2019 8:11 pm
by rbentnail
mzeist wrote: Tue Jan 01, 2019 3:08 pm You can indeed use USB to power the Zumo, but the USB connector is quite fragile, so if you choose this way maybe use an angled connector to remove some of the strain from the Zumo USB connector (like this one: https://buy.garmin.com/en-US/US/p/pn/010-12110-02)
Yeah, mine came with an automotive mount too but I surely would not use it on a bike. It's just a snap-in ball setup, very cheap. The cable linked looks like the one that comes with the new unit also, for use in the auto.
Posted: Tue Jan 01, 2019 9:56 pm
by mzeist
rbentnail wrote: Tue Jan 01, 2019 8:11 pm Yeah, mine came with an automotive mount too but I surely would not use it on a bike. It's just a snap-in ball setup, very cheap.
yes you're right, the auto mount is not very sturdy. I misread your post, thought you would put and use the Zumo in the tank bag somehow.
