Hi from Bundaberg Australia
Posted: Fri May 16, 2025 4:57 am
by Rens
Hi guys, just saying hello.
I joined honestly out of desperation .... I have a Zumo 660 that came with the BMW GS bike.
It decided to chuck a mickey with the PIN code that I was given to me by the previous owner.
The Garmin Australasia people can't help me.
So, I'm hoping one of you learned folks would be able and kind enough to help me solve this conundrum.
regards
Rens
Re: Hi from Bundaberg Australia
Posted: Fri May 16, 2025 5:36 am
Welcome to the forums @Rens .
"Chuck a Mickey" ? I've not heard that phrase before, had to look it up. The same as Uk "Throw a wobbler".
I can't help with the pin code. Maybe contact Garmin, or go back to the original owner ? I was going to suggest a system reset, but you probably cant do that until you've entered the pin.
Posted: Fri May 16, 2025 5:45 am
by Rens
Thanks for your reply. I tried your suggestions and no go.
Chucking a mickey is an Aussie term. Another one is having a hissy fit.
It basically means "The computer says no!" But you probably already worked that out. :lol:
Cheers
Rens
Posted: Fri May 16, 2025 6:11 am
I'll move this post into the Zumo 660 area, see if anyone can help.
Posted: Fri May 16, 2025 6:13 am
by Rens
Terrific. Thanks for your help.
