CN NA 2020.10
Posted: Wed Jan 30, 2019 4:06 pm
by sussamb
CN NA 2020.10 just been released.
Re: CN NA 2020.10
Posted: Fri Feb 01, 2019 12:12 am
by carolinarider09
Has anyone loaded it and tried some routes with it yet.
2019.10 was not a good release and caused issues.
Re: CN NA 2020.10
Posted: Fri Feb 01, 2019 12:36 am
by JD Hog
I loaded it and just did a route with no problems. Didn't download to GPS yet though.
Re: CN NA 2020.10
Posted: Fri Feb 01, 2019 12:38 am
by carolinarider09
Thanks. I will wait a couple more days before I down load it to one of my GPS and test it and see what happens.
Update 2/4/2019
Just completed adding the new maps to my family of GPS's and, with the exception of loading the maps on my 550, everything went well. I have not tried any routing but will do that tomorrow if the weather forecast holds.
Re: CN NA 2020.10
Posted: Tue Feb 19, 2019 4:06 pm
by redpattison
Downloaded it and did a run to Florida from Toronto. Worked fine from my front room. If that means anything?
Re: CN NA 2020.10
Posted: Wed Feb 20, 2019 2:48 am
by carolinarider09
I did two local routes over the past several days. Its an issue I had with the first update in 2017. This time no issues.
Having said that, all the routes were point to point (i.e. no waypoints).
