Zumo XT3 and XT3s are introduced
Dutchgixxer
- Has liked: 13 times
- Been liked: 27 times
https://www.gps.nl/motornavigatie/garmin_zumo_xt3.html
first impression of the new zumo models. To be seen at the motorbeurs in Utrecht ( NL)
- twowheelstom
- Has liked: 146 times
- Been liked: 54 times
Re: Zumo XT3 and XT3s are introduced
XT3 comes in 2 sizes,
the XT is 5.5 inch
the XT2 is 6.0 inch
the XT3 compact 4.7 inch (i call this one the XT3s) s for smaller version
and the XT3 6.0 inch (i call this one the XT3)
the XT is 5.5 inch
the XT2 is 6.0 inch
Last edited by twowheelstom on Thu Feb 19, 2026 12:39 pm, edited 2 times in total.
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
- twowheelstom
the TripManager software, developed by user FrankBijnen, is designed to work with Garmin Zūmo XT and XT2 devices and is expected to work with the new Zūmo XT3 (or the Zūmo XT2, which is the current direct successor).
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
In case you hadn't noticed. FrankBijnen that is me FrankB.twowheelstom wrote: Tue Feb 17, 2026 2:00 pm the TripManager software, developed by user FrankBijnen, is designed to work with Garmin Zūmo XT and XT2 devices and is expected to work with the new Zūmo XT3 (or the Zūmo XT2, which is the current direct successor).
I EXPECT that TripManager can be changed to support the new XT3, but the current version will likely not support it. That's why the sample files are needed
Frank
- twowheelstom
XT3 Internal Storage increased
XT 32GB
XT2 32GB
XT3 64GB
XT 32GB
XT2 32GB
XT3 64GB
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
- twowheelstom
SD Card sizes
for XT3 can use 32GB or 64GB microSDHC or microSDXC Class 10 but both needs to be in FAT32 Formatting
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
Well, there's a surprise. End of February, just in time for the start of the season at Easter.
So - the most pressing questions for me are:
Have they stopped the Tread App from Screwing up the routes - my recent experiments (this last week) suggest not.
Have they sorted out the other issues for the XT3: RUT behaviour for Imported routes; Changing route point names; moving the route and shaping points to a nearby faster road; Removing any missed route points once the route has been recalculated if you are not able to take the suggested turning; fixed the broken track log when RUT behaviour is in progress.
I don't know, but I would suspect not - some of those issues existed on the XT1 and were carried forward to the XT2.
So I wonder what happens with the issues with the XT2 now. Sorry sir, we no longer support the XT2 ?
I think I know what the answer will be. The same pattern of behaviour has happened before - it seems to be an economic model that works for them.
I don't think I'll be biting this time. I think I said that once before - but I'm getting too old for these games - and anyway I've got to learn how to ride with three wheels yet. I've only done 50 miles. The rate I am going, I'm not going to be riding far enough away from home to need a stanav.
If I bite it's for the fun of solving a puzzle. Not because my XT1 doesn't work as it should. (expensive puzzle!)
- Site Admin
- Has liked: 438 times
- Been liked: 265 times
