Need a pencil
Posted: Sun Apr 28, 2019 3:02 am
by camardelle
On the PC version of BC, there is an edit function that allows me to "rejoin" a route in progress and it's represented with a pencil icon. I can't find the option in my Mac version.
Any help?
Re: Need a pencil
Posted: Sun Apr 28, 2019 7:56 am
by advnzer
pencil icon?The pencil icon for me is "INSERT' a via or shaping point into a route.If you have two routes open there is an option to join two routes under the edit/advanced menus
Re: Need a pencil
Posted: Sun Apr 28, 2019 10:51 am
by camardelle
That's what I'm looking for...the "insert" function. Is that the same thing as joining two routes?
Re: Need a pencil
Posted: Sun Apr 28, 2019 1:06 pm
by Steve W
Open the route properties window of the route you want to re-join or extend. Activate the route tool (control r). Go to work.
To join two or more routes, open the route properties box of the first one and drag additions into the box in the order you want to add them.
Re: Need a pencil
Posted: Fri May 03, 2019 8:13 am
by advnzer
Steve W wrote: Sun Apr 28, 2019 1:06 pm Open the route properties window of the route you want to re-join or extend. Activate the route tool (control r). Go to work.
in windows and basecamp you have two routes open
